Compression Question
Discussion in 'Engine Building' started by 22crazy, Dec 25, 2002.
  1. 22crazy
    22crazy Senior Member
    what up. Ive been searching the net and asking people but nobody has been able to answer my question. I wouldnt mind building a crazy NA motor but the problem i face is compression vs octane. I no if someone wants to build a NA motor u need high compression, but the problem is that the higher compression u go, the higher octane u need to go. My problem is that in my area the highest octane u can buy at a pump is 94...i can buy octane boosters, but i dont want to buy a booster everytime i go to the pump. Does anyone no whats the highest compression u can have inside your engine using 94 octane before the gas spontaneously explodes because of compression :eek: instead of spark. Thanx
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Articles in above tabs,page 1,detonation ;)
  3. 22crazy
    what do u mean page 1....detonation?
  4. xj0hnx
    C.C.TX.
    I mean there is a article about detonation that will give you a good idea about the compession question you have in regards to octane levels.
  5. 22crazy
    where is the article? if it is the one in articles - detonation it only talks about psi...i need to no the compression of the pistons i need to buy so that it will work with the gas i can supply ( 94 octane )
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    i think calesta is running 12.5:1 on 93 octane, that is probably the highest i'd go on pump gas
  7. 22crazy
    ya 12.5:1 is pretty high too...and i no i can get 94 so i dunno i try messaging him and asking him...thanx for the post b16
  8. xj0hnx
    C.C.TX.
    Sorry never said it would give you the exact figures your looking for,just a good idea of the theory and from there the world is yours.
  9. 22crazy
  10. phunky.buddha
    Dallas / Fort Worth, TX
    12.6:1 on 93 :lol:
  11. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    Don't forget, if you're ever out of your comfort zone where 94 octane is NOT available, you will have to be able to run the highest octane rating available with a bottle of octane booster (usually .6-.8 octane) and not get detonation..just something to think about.
  12. davidbr
    davidbr Member
    would 13:1 safe on 99octane? sorry, but i dont want to make a new thread...
    i know no one can say for real, just guesses
  13. IMPORT PRO
    IMPORT PRO Junior Member
    David
    13.0:1 on 100 octane should work, but might nock and ping from predetination but won't harm the motor.
    for the 94 octane question yes, 11.0:1 will work even for highway use.
    That's coming from a honda/gm technician.
  14. pissedoffsol
    and you could always retard the dist. if you had to to get by on a tank of weaker gas, and NOT BEAT ON IT or take it up so high...
