Compression #'s For Obd1 B16
Discussion in 'Engine Building' started by seancooneyB16, Mar 11, 2003.
  1. seancooneyB16
    seancooneyB16 Member
    I'm going to be running a compression test on my OBD1 B16 soon what should my compression numbers be near?
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Minimum 184 maximum 200 according to the Helms.But this is for a US spec B16A3,so the JDM,EDM ones maybe a little higher since they run a slightly higher compression.
  4. ScrapinSi
    ScrapinSi Senior Member
    USDM B16a2 is is 170-200
  5. D See 2
    Baltimore, MD
    what should a JDM b16a push?
  6. HOOKUPSPROCRX
    HOOKUPSPROCRX Member
    upland ca
    anything over 175 is good just remember to do the compression test with the throttle plate cmpletely open this is the right way to do it.
