Converting a P28 to run a 1-wire O2 sensor...
Discussion in 'ECU's, Electronics, and Tuning' started by civicious, Jan 1, 2006.
  1. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    First of, don't tell me 'Just get a P08' or 'Just chip it!' I'm not getting a P08, and I'm not chipping it. I've read that there may be a difference in the fuel/timing maps on the P28 versus the P08, with the P08 being more aggressive, but I really don't give a shit as I'm not going to be racing anyone with the stock D15.
    OK, I know that to convert a P05 to run a 4-wire O2 sensor, all you have to do is add a NPN digital transistor (C144) at Q30.
    Now, I'm going to be running a P28 on a D15B in a 90 CRX...I've got the OBD0-OBD1 jumper that has the 4 wires for the O2 sensor, BUT the motor came with a 1-wire, and the CRX isn't wired for a 4-wire...The reason I'm running a P28 is because NOONE had a P08 in stock, and I got a virgin 5spd P28 for a great price from JHP...I'm planning on chipping the P28 this summer when I go turbo, but I am NOT chipping it until then (so don't tell me to just chip it and disable the O2 heater...I already know I can do this, but I'm NOT chipping this ECU yet.)
    My question is this...If the only thing required to ADD the heater to the 4-wire O2 sensor is the C144 transistor at Q30, could I just REMOVE the transistor from the P28 and run the 1-wire O2 sensor without any problems? Also, will this affect VTEC engagement?
    Thanks in advance...
  2. GSRCRXsi
    MD
    just get a 4-wire you asshole :p
  3. civicious
    Houston, TX
    Unless, of course, someone has a spare one they'd be willing to donate :mrgreen:
  4. jamesA
    hahaha
    I'll help you find a P08 if you sell me that p28 for 115 shipped. :p
  5. pissedoffsol
    dude, just go to autozone and pick up a generic bosch 4-wire o2. its the same shit.
  6. Taco15
    Tallahassee Fl
    damn dude. Tell ya what...i'll send you a 4 wire 02 and you pay for shipping. hows that.
  7. SixtySecondAssassin
    Austin, TX
    sounds like a solid theory. give it a try!
    the jumper harness should be ready to accept a 4 wire o2 sensor, you'll probably want to put one in sooner or later.
  8. jamesA
    Taco rocks. lol
  9. civicious
    Houston, TX
    Lol...I'm chipping the ECU and keeping the 1-wire until I get a WB...
    Thanks though :thumbsup:
  10. Taco15
    Tallahassee Fl
    all right fine. still gotem for a while so lmk if you end up needing them:lol:
  11. xenocron
    xenocron Member
    Bergen Co., NJ
    To throw some info out there, yes it only takes adding one transistor to a P05 ECU so that you can run a 4 wire O2, BUT, the program on the P05 ECU still thinks there is only a single wire O2 so you need to change the program (IE - chipping). Same with a P28. You can run a single wire O2, but the ECU needs to know that its a single wire (IE, the computer needs to be chipped so you can disable the O2 heater)
  12. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Wow, I didn't know Chris was on this site too. Where have I been? Why didn't you just get a chipped pm6 :)
  13. civicious
    Houston, TX
    I got a P08. 1 wire 02 sensor + right ECU for my motor without chipping = t3h win!
