converting obdII to obdI
Discussion in 'ECU's, Electronics, and Tuning' started by brasilianstreet, Apr 7, 2004.
  1. brasilianstreet
    brasilianstreet Senior Member
    how do i do this what do i need new ? i have a b16 si head b18 ls block and b16 jdm obdII tranny and im puting it into my obdII 96 ex coupe i heard to do a ls-vtec with my set up i need obdI in my car?
  2. tiNee
    tiNee Junior Member
    why not just buy a jumper that hooks up to the ecu harness that lets you run obd1 ecus :)
  3. E_SolSi
    why would you need to go OBD-1???
    if the engine is OBD-2 and the car is OBD-2 then i dont see why you would have to run it OBD-1
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    run everything as you would in an obd2 car. then get something like the skunk2 ecu harness that just transfers the every thing over so that you can run an OBD1 ecu. simple.
  5. CRX-YEM
    Wallingford, CT
    you going to want to keep in mind the implications you might run into with emissions testing as well. as most states now for obd-II cars just plug into the ALDL conenctor to look for engine codes.
  6. brasilianstreet
    o well i had someone tell me that i had to tranfer my car into obdII ? so your saying i wouldnt have to
