Corrado Big Brakes Anyone?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by 88bluehf, Jul 7, 2005.
  1. 88bluehf
    88bluehf Senior Member
    Denton,TX
    First off I have a 88 CRX Hf and I am upgrading my brake system. I have read that you can use 90VW corrado rotors, 91 ex spindles and itr calipers. Well i purchased all componnents and tried to do a test fit before I installed them on the car and the rotor WILL NOT fit on the spindle. I thought they would work on 4G spindles but not the 5G's. I will be switching to Re-drilled Prelude VTEC rotors, but I guess im wondering why my setup doesnt work when I have read that it does.
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    you can fit the lude vtec rotors on there?
    those are huge...
    and i dunno anything about using corrado rotors...
    it seems they should fit since corrado is 4x100
    where is it not fitting?
    did you try it on both the ex spindles and the hf spindles?
    are you sure you have ex spindles?
    and are you sure they are the right rotors?
    link to the write up?
  3. 88bluehf
    Denton,TX
    ludes need to be redrilled...bought them today will machine tomorrow
    i pulled the ex spindles myself so they are a definite.
    i wish i would have saved the write up but i cand find it now.
    o well, should have known to avoid VW.
  4. 88bluehf
    Denton,TX
    You are..thats what i have.
  5. 88bluehf
    Denton,TX
    very true...i think im going to do the swap today...i hope i dont run into anymore problems..
  6. 88bluehf
    Denton,TX
    Finally the Brakes are done...The end result is absolutely fantastic. I am very pleased.
  7. brian11to1
    brian11to1 Senior Member
    thats fucking sweet, wish i had an EF. but, ive got a write up for a similar break upgrade for da integra's... i cant wait. what sort of improvement as far as braking did you see?
    wanna do some tests... to compare to stock. say from a 60 stop teh brakes and see how long it takes to stop like car and driver did back when the car was new?
    just a thought.
    one more thing, are the itr calipers 2 or 1 piston?
  8. 88bluehf
    Denton,TX
    THANKS!!!
    yeah its basically the same for da's, but you dont have to change the spindles though. i can say without a doubt the braking is SIGNIFICANTLY improved. I would like to do some test, but i bet it can stop in 60%of the stock distance from 60-0. (my stock setup was 9.1" not too impressive) I used to lock my ish up quite regularly but with the limited test i have performed in the current break in period i have noticed that i have much more control over whats going on. i am running single piston right now, but i am looking at upgrading to the dual piston model. Never hurts to upgrade right?
  9. 88bluehf
    Denton,TX
    its an awesome mod IMO....beats spending 1000 bucks on a big brake setup..
    i went with the calipers bc accord wagon, legend, prelude vtec, itr are all basically the same...plus i got a good deal...lol..i can give you a full list of what cars came with these calipers if you are interested.
  10. 88bluehf
    Denton,TX
    94+prelude VTEC, ACURA Vigor, Acura LEgend 91+,ITR, CL, TL, Accord V6,NSX, ACCORD wagon and i think CRV
  11. brian11to1
    you never answered or i just overlooked it... are the 2 or 1 pistons caliper. If i remember they are 2.
  12. brian11to1
    oooooooops... i overlooked it.
    fucking sweet.
    so, i take it the single piston is larger than a single piston on a da's brakes or are they the same size... i so cant wait to do this.
  13. 88bluehf
    Denton,TX
    considerably larger....before i upgraded my MC the pedal feel was waaaaaaaay to mushy.
  14. 88bluehf
    Denton,TX
    this is probably one of the best upgrades i have done to my car...i have found an article on how to put 10.3's on the rear, so i think that is my next upgrade..more stopping power for the 1800lb rex...lol
  15. brian11to1
    10.3 is what the integra's have stock, in the front... that is sweeet... more pictures uh?
    can you give a complete run down of the install w/pictures please?
  16. 88bluehf
    Denton,TX
    pictures of my install on front? if so ill tear one side down tomorrow and take some detailed pics. Ill give a link for the 10.3 rears as soon as i find where i saved it at in my computer...lol.
  17. brian11to1
    will it apply to the integra upgrade...
  18. 88bluehf
    Denton,TX
    its exactly the same as far as i know.
