Crank pulley bolt
Discussion in 'General Tech and Maintenance' started by SolidDreamz, Oct 15, 2002.
  1. SolidDreamz
    SolidDreamz Senior Member
    va beach,pa,oh
    Im doing my head gasket now and we cant get the bolt to pull the crank pulley off. We're using a snap on pneumatic gun at 145psi and the bitc@ wont budge. Is there any way that the bolt is backwards and counter clockwise tightens it? I got my head off though and put TDC marks for piston 1 on the belt and cam so the timing wont be screwed. After looking at the block I can tell now whomever owned the car rebuilt the engine, has a new timing belt and crap. Block is in good condition but wondering why id get white smoke on startup only and bubbles in radiator. Warped head? I dont think the head is cracked because once i drive no smoke comes out. The head gasket looks decent too. If the head is warped how much does it cost to fix? Anyone know what I can do tomake this car run great before I put everything together? THanks
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    No it is not a reverse thread. The easiest thing I found to get it off was order the crank pulley tool from Honda. They have a tool that slips into the crank pulley and braces itself against the chassis that hold the pulley in place. The tool has a hole in it that allows you to put a breaker bar with a 19mm socket through it and torque that bitch off. The crank tool is expensive (like $60) but worth it. Some one else (I believe that it is Snap-On) makes the same tool with a longer arm for use on motors outside the car.
  3. SolidDreamz
    va beach,pa,oh
    hey if my compression in a 93 civic dx was between 185-190 in all cylinders then that would logically mean that the head was not warped or cracked just the gasket starting to go bad? Also when i looked at me head gasket is the gasket supposed to run in between the cylinder walls (I.E. - left and right sides of cylinder going up.) Because I have no gasket in on the left and right side of each cylinder. What parts should I buy when i go to put everything together? My timing belt is already new. If I cant get the crank pulley off then I cant replace the water pump. Should I replace the timing tensioner? thanks alot!
  4. lsvtec
    The tensioner should be fine. How far away is the closest Honda dealer from you?
  5. SolidDreamz
    va beach,pa,oh
    lol, i dunno why? I drove 600 miles on a bad gasket to fix this car myself instead of paying 900.00 bucks so I drove from Va beach to ohio. Not sure. Surprised I made it here though! Do you think the heads not warped because I had good compression?
  6. pissedoffsol
    those compression numbers are fine-- remember- its the VARRIANCE that matters, not the actual numbers.
    = or- 10% is ideal. 15% is ok 17 you got issues.
    your head gasket should look something like this:
    if you are missing peices of it... I dunno WTF you were doing??? lol
  7. SolidDreamz
    va beach,pa,oh
    damn, the 3 really think layers of metal inbetween the cylinders are totally missing on my gasket! So I guess It was the gasket going bad. How much does it cost to resurface a head so i can throw it back on with a new gasket?
  8. pissedoffsol
    keep in mind the pic is a SPOON headgasket....
  9. SolidDreamz
    va beach,pa,oh
    well i thought that all gaskets should have the piece running in between the cylinder walls.
  10. SolidDreamz
    va beach,pa,oh
    anyone know how much it cost to get your rotors turned?
  11. lsvtec
    The resurface should cost between $20 and $30 depending on the shape of the cylinder head.
