I am having a motor rebuilt right now and the shop wants to put a reground crankshaft on that is .25mm under spec. Will this be OK for a setup that will run 190-200hp off a turbo? Is there anything else to check for and what type of bearings should be run since OEM really would not apply with this crank? Will this be ok instead of purchasing a new $800 crankshaft from honda?? I need to let the shop now asap.
