Crower cam markings
araychel
Is there any way to distinguish between OEM and Crower cams? I was told I have a set of Crower 62403's and I measured the lobe height with a caliper and compared it to the lobe height of a stock B18A cam. There is a .010" difference, but they look exactly the same, if you put the two cams next to each other you couldn't tell the difference. I know that doesn't mean anything because the differences will be subtle, but I just want to know if there is some sort of markings that Crower puts on their cams.
And by the way, I can't call Crower because they are closed for the next 10 days I believe.
I have the 62403-2 cams and they both say "Crower" on them, the intake and the exhaust, besides that I think its the only marking.
Originally posted by brian11to1@Dec 29 2004, 04:36 PM
simple... as integraslut said. Look for CROWER on teh actual cam itself.
[post=438796]Quoted post[/post]​
Where is it supposed to say that? I am trying to get some more info on this so have some recourse with the Ebay seller.
