Crower Cams
Discussion in 'Forced Induction' started by redtao, Jan 30, 2003.
  1. redtao
    redtao Member
    I have a b16 with the greddy setup and was thinking about the crower stage 2 cams, has anyone had any experience with these?
  2. pissedoffsol
    they are pretty good cams. just make sure yo have the valve train to hold them, as they are much higher lift than stock.
  3. redtao
    redtao Member
    hey, thanks, i called crower but the guy over the phone sounded like he wasn't really even listening to me and he just wanted to sell the cams. You wouldn't know of anyone who as them or of any reviews on the net that would have some dyno figures, would you?
  4. pissedoffsol
    stage 2- which ones? the 402t?
  5. redtao
    redtao Member
    well the one's that i want are the 63401t but if you've see some others that would be helpful to.
  6. redtao
    redtao Member
    see crower has some dyno sheets for the n/a cams but none for f/i, i bet it is cause all the different setups that you could have with f/i, but my thought is atleast let us know that these cams are for real and show one dyno so we can go from there.
  7. pissedoffsol
    the 401t are a mild cam- basically, its going to shorten duration slightly, if not keeping it the same, and up the lift a few for better turbo air in/out functions
    the 402t are still a moderate cam- very streetable. near-stock duration, much higher lift.
    as for no dyno's, i think yo uare right with the boost setups being all different.
    IMO, on a small turbo: 14g, t3 or smaller go with the 401t
    on a med- to big turbo: t3/t4, t4+ , go with the 402t or something even bigger
  8. redtao
    redtao Member
    the 400 are the stock replacement and 401t is the stage 2, right. so the 402t are those like a stage 3?
    i have an TD05H-18G ,so you would go 401t with that one?
  9. redtao
    redtao Member
    oh i see your cam product id are for the ls the dohc numbers are a little different.
    hey i didn't tell you i have a 97' delsol vtec, bought it of the lot. runs great with that
    greddy kit(the kit for the civic si). You also have a sol, right? it is good to see some
    performance sols.
  10. pissedoffsol
    yeah i have a sol, goin 2.0 gsr/t with it shortly
    if i were you, id run the 402ts and upgrade the turbo :)
    but if you dont plan to upgrade, get the 401t's
