Hello, i was just wondering if anyone has had experience with either crane or crower. Im planning to build an LS all-motor and i was just wondering what camshafts i should go with. I heard both companies are good and ive been trying to find info on the crane cams. For the crowers, i was looking at the 62404's:
Advertised Duration-----Duration @ .050"------Gross Lift w/1.75
------249 / 251---------------216 / 218------------.446 / .432
and the cranes 101-0016, i found these specs:
------advertised duration----duration at .050----lobe sep-------gross lift
-------------274/274--------------218/218-----------108-----------433/433
the specs for 101-0018 are at:
http://64.90.9.168/SpecCard/DisplayCatalog...asp?pn=101-0018
There close except for the duration and the lift....is longer duration better for all-motor, or more lift? can someone explain what each caterogy means and which cams would be better? any pro's or cons on either company. Your feedback would be helpfull, thanks in advance.
