I have a 90 crx si with a b16a swap in it. it needs a clutch and a valve cover gasket. i dont know what to tell the guy at the parts store for what model car i need it for. can any 1 help me out? thanks
that's only right for the valve cover gasket, for the clutch it will depend on what year engine/trans is in there. if it's a cable y1 or s1 trans, you'll need a 90-91 clutch disc. if it's a cable ys1 you'll need the disc off of a 92-93 integra (it has a larger input shaft.) and if it's a hydrolic clutch, then you'll need the clutch from a 94-01 integra. all of the pressure plates will be the same, only the disc matters.
