I swap a d16z6 into my dx crx. Its throwing code 1 is no. 1 cylinder position another is manifold absolute pressure,coolant temperature, electronic load detector. wat do these mean im trying to figure it out but im still just learning about my car
no. 1 cylindar position is your dizzy, MAP is your MAP sensor, coolant temp is yourcolant temp sensor, and I dont know what the load detector is, double check your wiring, clear the codes and see if they come up again.
Code 1 is an O2 sensor. If I am not mistaken, there is another thread that was up just a few days ago about a load sensor. Actually, I think there was two threads about it. Might wanna use the search bar and see if you can find that.
