ok i have an ls swap in my 91 crx dx but the damn thing will no longer run and suspect faulty wiring but since i cant locate the source of the problem i came to the idea of just changin out harnessess gong from the dx to the si does anyone know of any problems i might run into changing the wiring. Also does anyone know what harness you can use that simplifis the ls into the Si swap or can you use the stock si engine harness?
any help is much appreciated
RYan
RYan
