i was replaceing the fuel pump in my crx, and the 2 bolts that hold on the 2 straps broke... what am i supost to do? and where could i get those bolts?
i would just run to the hardware store. its just a nut a bolt. nothing special. you could try the junk yard, but you're going to get 20 year old bolts from there.
well the strap bolts are bent on the top to slide into the groove on the body. either find a honda dealer or snatch some new bolts from the hardware store and bend em to fit in the grooves would fix such a problem
