i have a 91 crx hf and would like to put in an engine from a 88 crx si, can it be done and how. i was told wireing wouldnt match up,is there a fix to this problem
even though it will bolt up with no prob. will all the wireing hook up to the car that was hooked to the 91 hf engine,remember im putting in a 88 si engine. takeing out a D15B6 and puting in a D16A6 are you sure all the wireing and vacume lines and all will hook up right?
hey guys,thanks for all the helpone more question,i have the whole si car that the d16a6 came from,is there anything i should take out to put into the hf outside of the ecu?
