crx help
Discussion in 'HYBRID -> ED-EF / DA' started by TITO.CIVIC, Mar 26, 2009.
  1. TITO.CIVIC
    TITO.CIVIC New Member
    I have a 88 crx si the sunroof don't work and I'll like to know if the ef or da sunroof work in my crx let me know pleace
  2. BrokenRex
    BrokenRex New Member
    your car is an EF, the DA sunroof wont fit.
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    and the hatch sunroof wont fit either.
  4. D16SiHatch
    D16SiHatch New Member
    yep, what they said. and before you go ripping out the sunroof have you actually checked to see if there is something physically wrong with it. is the signal for the motor to turn even reaching the sunroof. is the motor itself bad, those can be replaced as well without replacing the whole sunroof.
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    or it could be the fuse
