crx rear seat install
CRX-YEM
Super Moderator
Moderator
VIP
ok well, I have a jdm rear seat with all hardware and seat blets. Started taking the crx rear panels apart, and it loks as if the lap belt mounting locations are present but not the for the buckle. So is anyone familiar with this install, or have some better pics than the two posts I've seen on honda-tech. I've tried googling not much help really. As far as the hardware for the seat back I need to weld in two of the brackets, no big, deal it's really just the seat belt locations I need info on.
Thanks in advance
Dennis
you have to get the mounting tabs welding in for the the belts. a friend of mine has the rear seat in his crx and I have to say :pimp: he told me he had to weld in the brackets. I was going to get one for my crx but i sold it before I got one
before you weld in seat belts think about if you know how to weld properly.
You will need to fish plating before you weld the belts down to sheet metal
well simple enough then , look like I'll be welding the seat buckles in soon
as well as the swivle for the seat back, everything else has the standard bolt locations present, thanks for the help
