will a 90 crx Si distributor run on a DOHC zc motor? assuming i wire the cam sensor. or do i need an 89 integra one. seems stupid to get an 89 integra and change the plug over if i can just use a crx si one.
the Si distributor won't bolt onto the ZC head - you may get one bolt in it, but the distributor will be in the wrong location and you won't be able to set the ignition timing correctly
