Where is the fitv "fast idle throttle valve" located on a d16a6 im?????? it's not below the throttle body like i've seen in other pictures. I also have just one hole in the TB instead of two. I believe this hole is for the iacv "idle air control valve" there ic not another for the fitv. is the fitv inside the iacv? I'm lost and need help. thanks in advance!
