like the title says i need to know if i can use the crx si rear disk brake setup on my civic?
i have a crx si that im parting so i can take the entire disk setup from that but will i need to replace my master cylinder? and i also have a 40/40 prop valve should i use that or the stock crx si prop valve? and will the crx e-brake cables be long enough?
any help will be greatly appreciated. so thanks in advance for any help. -mike
