Crx Tranny Ground
Discussion in 'General Tech and Maintenance' started by CRX_Si, May 28, 2003.
  1. CRX_Si
    CRX_Si Senior Member
    Lynchburg VA
    on my 91 CRX Si there is a ground wire connecting the tranny and the negative battery terminal. before it reaches the terminal it is being held down to the basin on the bottom of the engine bay. i am upgrading the ground wires mostly for looks. can i make two wires, one for the negative battery terminal to a ground and one from the tranny to a different ground? thanks
