Crx W/built Zc Motor And Turbo
Discussion in 'HYBRID -> EG-EK / DC' started by boostin21, Mar 31, 2003.
  1. boostin21
    boostin21 Junior Member
    hey guys. i hope you guys can answer my question. what do you think a crx w/a built zc motor and t3/t4 turbo would run in the 1/4 mile? im thinking about doing this and would really like some input. thanks.
    also, how much wheel hp do you think ill be making with this set up?
  2. latinoxpress
    latinoxpress Guest
    Last week, I was at the tracks in englishtown NJ and I saw a 1986 civic hatch with a ZC engine running 10 Lbs of boost pull a 13.6 in a 1/4 mile. He did this with 16 inch wheels, no slicks!! It all depends on how you build the engine. Hope this helps a little.
  3. Roro
    Roro Member
    you could in theory have it run 10s if you had the money...
    but a zc motor with a turbo could also pull out a 15... it all depends on driver + motor and whats done to it
  4. crxracing77
    crxracing77 Senior Member
    west lafayette in or clw florida
    best way to find out is to do it.... That what im doing your never gonna have a good answer unless you just do it your self!
