ctr pistons
Discussion in 'General Tech and Maintenance' started by driver1, Apr 5, 2004.
  1. driver1
    driver1 Senior Member
    i was just curious what the compression is for ctr pistons, and also what u guys might think would be a good piston to go with for an all motor setup with failry high compression and stage 2 or 3 cams? engine is b18b1 gonna have the head completely done and now im wonderin what i should do for a bottom end to get some decent compression thanks
  2. typesiracing
    typesiracing Senior Member
    ny
    those would definately be decent pistons to go with.....a calculator i used showed 11.7cr with stock deck height and stock head gasket...i can't vouche for the accuracy of it but it'll be ballpark
  3. driver1
    Does anyone else have any info or advice on this?
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    as far as CR is concerned, check out Cspeeds site
  5. pissedoffsol
  6. driver1
    uhh that site didnt really do anything for me i found some listings for a million different ek9 civic piston sets but nothing about specific, ctr pisons or compression ratios?
  7. JDMilan
    Boca Raton, FL
    dude, put in your components and then you'll find out what CR you have
