does anyone know the biggest lift cams you can use when running ctr pistons in a b16a block with b16a head. stock valves. and the max valve lift on the intake cam is 12.5mm (.49"). will there be any valve clearance issues?
zex stage 2's https://hondaswap.com/reference/index.php?mode=zex. they are comparable to the skunk2 stage 3's. zex has them in their project car with JE 10.5:1 cr pistons in a GSR block. but i want to know if they will have problems with 10.8:1 cr with ctr pistons in a b16a block.
yea, i was guessing that, i was just wondering if anyone had any experience with pistons/cams and could give me some info or good sites to look at. thx B16
does anyone know the biggest lift cams you can use when running ctr pistons in a b16a block with b16a head. stock valves. and the max valve lift on the intake cam is 12.5mm (.49"). will there be any valve clearance issues.
the cam that you have is not gonna touch the ctr pistons if you have a unmilled head. so make sure the head havent milled.
check out this site. There are three guys (i suppose guys) that will know the answer or at least be able to point you in the right direction. Like claying them.
