CYP sensor?
Discussion in 'ECU's, Electronics, and Tuning' started by SpoonTuNed, Sep 24, 2006.
  1. SpoonTuNed
    SpoonTuNed Senior Member
    Im throwin a code 9 which is for cyp sensor. What the heck causes that and how do i fix it?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Could be:
    bad distributor
    cam timing off a tooth on timing belt
    incorrect distributor timing (usually not)
  3. LateApex31
    LateApex31 New Member
    Even if cam timing is off a tooth, the ECU has no way to know this and will not throw a code 9. The TDC, cam position, and crank position sensors are all driven from the distributor so there is no way for one to move relative to another.
    It could also be the wiring to that sensor, or the VR pickup is too far from the totherd wheel or there is debris in there that has damaged the wheel. Bottom line, check the dizzy and its associated wiring.
  4. xips(86CRXSI)
    xips(86CRXSI) New Member
    Portland, OR
    I'm having the same problem I rewired the wires going to it and still got the code, I guess I'll have to take apart the distributor and check if the VR pickup is too far from the totherd wheel or if there is debris in there that has damaged the wheel? Is that what I should do next? Thanks
