If you look around, you might find some, but solid mounts normally cost a fortune. On b-series they cost 200+. Have you considered making your own solid mounts? Check out the Mount solidifaction post on the top of one of the tech forums.
depends on how solid you want them. you could go and get some fabbed up from 1/4" steel sheet and they would never move. teeth would fall out but the engine would never move
