D15/16 SOHC Header on my D16A1
xips(86CRXSI)
Does anyone know if the header off a D15/16 Civic SOHC 88-00, will fit on my 1988 D16A1 DOHC Teg engine thats going in my 86 CRX SI?
It probably will, but the ports may be different and you will have grind them out. The d16a1 is probably the closest thing to a dohc zc as you can get, if you have to grind away a header for that engine then you probably will for yours. If the header is in a junkyard or a buddys house, take the gasket and compare it to the header you want to use, or take the gasket of the header you want to use and put it on your engine, that way you can tell right away.
yes, it will fit, port matching is not necessary
PM me if you have any questions, i have done this swap and drive it daily..
