Originally posted by 91crx@Sep 27 2004, 05:38 PM
just us ethe ecu for a 92-95 civic ex , you will need to wire it for vtec, also yu will need a 88-91 crx si tranny you will need a obd 0 dizzy unless you want to run it as obd1 where you would have to get an obd0 to obd1 conversion harness
[post=395415]Quoted post[/post]
could i use my dizzy and will the 92-95 ex ecu fit my ecu plugs if not how can i fix this problem i want to stay obd0 thanks for the info could i just use a vtec controller for the vtec also could i use a crx si intake manifold to because i have it and the trans
[post=395456]Quoted post[/post]
