d15b ecu
Discussion in 'ECU's, Electronics, and Tuning' started by d15bsedan, Sep 24, 2007.
  1. d15bsedan
    d15bsedan New Member
    does anybody know what the stock ecu is on a 92 civic lx? it has a jdm d15b with no vtec solenoid and i need to figure out if i need to get a vtec ecu.
  2. austinkli
    austinkli The Blackberry Dude
    Jacksonville, Fl
    that would actually bew a d15b7 if it doesn't have vtec hommie. just a stoc ecu will be fine, don't get one for vtec, it won't work right if you got a d15b7.
  3. BrutalB83
    Rochester Hills, MI
    If there's no VTEC solenoid, then you've got no VTEC. Why would you need a VTEC ECU?
  4. larios2281
    larios2281 New Member
  5. xXRikan215Xx
    xXRikan215Xx New Member
    Philly
    what ecu would you need for an automatic D15b Vtec?
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    P08, although P28 works fine.
  7. BrutalB83
    Rochester Hills, MI
    You need to stop asking the same question in 50 different threads. One thread is sufficient.
  8. xXRikan215Xx
    Philly
    Im trying to get as much info from as many places as i could. Y do you care how many times i ask in diff threads.
  9. K2e2vin
    Raleigh, NC
    Because it clutters up the board.
  10. BrutalB83
    Rochester Hills, MI
    You're jacking other people's threads. Start your own threads and keep your questions contained in them. If you're not getting the answers you want then bump them.
