D15b running rich at operating temperature
chaz is this in ur eg? if so its obd-1 witch is a 4 wire heated o2 sensor. and ur ecu i have a p28 ill sell you that may help its off a d16z6 idk if u have the d15b vtec motor but it should help.
Come to think of it, my brother's MAP wires were reversed too but we caught that before we got it on the road.
P08, a JDM ECU, uses 1-wire O2 and is OBD1. It is the correct ECU for his motor.
Read the previous posts please guys. My D15b is running awesome. I'm using a p08 ECU with a ONE wire o2 sensor which is what its supposed to be paired with. If I had a p28 ECU I'd need a FOUR wire o2 sensor.
All I did was pull the four wires out of the connectors for my 4 wire o2 sensor that my D15b7 utilized and take the one wire I needed and put it in the one wire o2 connector assembly that the D15b uses. Pretty simple guys.
