d15b2 smokin'drippin,
Discussion in 'General Tech and Maintenance' started by 91civisedaner, Feb 8, 2009.
  1. 91civisedaner
    91civisedaner Senior Citizen
    oregon city or
    I've been wrenchin' on my new ride[91 civic sedan lx] and it's drippin' coolant.ok needs water pump.then the mf'er starts blowin' white/blue out the tailpipe.i mean really bad,james bond smoke screen style, I'm thinkin'it's a head gasket?? anyone have an opinion??
  2. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    hahaha the same thing happened to my civ after i did MPFI swap, i don't know for sure but i think it might indicate a head gasket, if it's really bad i supposed it could be piston rings or valve seals...?
  3. 91civisedaner
    oregon city or
    funny thing is she pulls real hard and runs great! She's also been sittin' quite awhile with a tiny bit o' gas,so i threw in some heet and put 5gal. of 92 in her,maybe water in the tank???she was runnin' real crappy before i put in the heet and new gas.
  4. 91civisedaner
    oregon city or
    so i guess NO ONE has an opinion on this??? I'm changin' the headgasket this friday..
  5. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    water in the the tank would just mix with the fuel
    white and blue smoke indicate oil or coolant in the combustion chamber, possiably head gasket
  6. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    run some seafoam to clean her out maybe, its a last attempt. But it's probably the headgasket.
  7. 91civisedaner
    oregon city or
    OK,so i changed the headgasket she still smokes white. a mechanic friend said it's water in the cat so i tried to drive it home she ran great for 2 miles then the oil light came on i stopped and topped the oil then she started knockin' real bad,i have since ordered a jdm replacement d15 it was only $635 with shipping.i plan on rebuilding the old motor after the swap.the new motor has 40k on it and a warrenty.
  8. dacheat
    dacheat ..is grounded.
    strongbadia
    i thought white smoke was antifreeze. :shrug:
  9. auth3nt1c
    auth3nt1c New Member
    im having the same dayum problem..check your coolant, see if their's oil in there! or try looking on your dip stick, see if its creamy. im waiting for my headgasket to come in. took it out to stretch her legs, and it rips like crazy....ill let you know how it goes..g/l!
  10. Ethan
    Ethan Well-Known Member
    Sounds like head gasket to me. Its 25 bucks for a cheap one so just change it.
  11. eastbxc
    eastbxc Custom User Title
    Kansas
    Read above. He already said he replaced the headgasket now he is getting a different motor.
  12. Ethan
    ohh shit that's my dad missing this post.
    make sure you post pics.
  13. 91civisedaner
    oregon city or
    oil was fine,new engine in she runs like a champ,god bless imported low mileage engines!!
  14. Ethan
    wanna pay for mine now?
  15. 91civisedaner
    oregon city or
    yeah if i win the lottery
  16. Ethan
