D15b7 Mods
turboman200
What type of modifications should i do to my d15 its in a 92 civic 4door. I plan to put a turbo on it ,but i want to do more to it. I herd about TB from a b engine will fit so im working on getting that. What other modifications should i do before i put my turbo on.
jesse :spin:
depends on the type of stuff you wantto do with your car. if you want to r0ll some 19's and have a bumpin' stereo maybe you should skip the engine mods that won't help with the looks of your car.
but if you want to go fast, you've come to the right place.
:werd: right place, wrong engine. I had that worthless piece of crap before I bought a sol. the engine is so weak, putting a Greddy full catback on it decreased power becuase the engine lacks hp/tq. on a Good note, you can do a mini-me (y8 head swap on the b7 block. Most aftermarket parts for a D16Z6 work with the B7 (header/pistons/rods/intake/etc)
well the stuff i want to do to my car is all performence first then looks later. i want it to go fast and look like a sleeper. i wanna do like 13s14s in the 1/4 mile if possible. im willing to spend some money not a whole lot but enough for what i want to do i wanna be able to beet most of the cars in my citydo u think u could help me on some info on how to do that.thanks
jesse :spin:
If it's fast and good, it's not cheap
If it's fast and cheap, it's not good
If it's good and cheap, it's not fast.
13 seconds huh? I see a swap in your future then. Or a built z6 wirh N20.
No internals are good for it. OEM pistons are the only pistons you should use in a D build up. They are cheap and offer a variety of cr options. Don't plan on turboing a B7. Spend $100 on a D16A6 longblock and swap it out if you want turbo. If you want to do stuff to this motor do a search it has been covered a lot lately.
Block guard, junkyard turbo with low boost. Sounds like that would make you happy
