hi every body .....any body can tell me at what dregres the ignition timing its supose to be on a d15bvtec(normal not 3 stage vtec motor) somebody told me its supose to be at the red mark ... any body can comfirme this?? thx a lot
ok but 16 degres,it is the red mark on the crank poulie l..l..l.......l ...l..........l red m. tdc mark is that ok like that
uh, you are talking about two different types of timing. The mechanical timing of the motor you measure on the pulley. The only mark that I know of is the tdc mark on the crank pulley. To set ignition timing, you set the little timing advance dial on the back of the timing light to what ever you want, apparently it is 16 degrees advance according to B18C_NA, and them you attach the little thing hang off of the timing light to the #one cyl. plug wire, and aim the light at the pulley. if the light makes the mark on the pulley stationary, you're good, if it moves, or you can't see the mark, turn the distributor until you can. Hope this helps.
