d15z1/d16z6 swap question
Discussion in 'HYBRID -> EG-EK / DC' started by cgeg5hb90, Feb 10, 2011.
  1. cgeg5hb90
    cgeg5hb90 New Member
    I swapped my d15z1 to d16z6. The whole rewiring the o2 sensor thing. Is there a way I can use the 7 wire o2 sensor. To work as a 4 wire. My 4 wire o2 sensor is sezed in my other header that is cracked. And a new o2 sensor = 80$
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Nope, they're designed/work differently...and the Z6 ECU can't read the 7-wire O2 correctly.
    Look for a used 4-wire O2 sensor(should be plentiful) or a universal one. If anything, save your 7-wire O2...those are expensive(assuming it's still good).
  3. cgeg5hb90
    Yea the seven wire is good I bought it 3 weeks ago. That's why I was asking but tnx bro for the info
