D15z6
Discussion in 'Engine Building' started by calvin, Oct 8, 2002.
  1. calvin
    calvin Senior Member
    NETHERLANDS
    I almost got every thing for a mini me swap.
    short block d15b7
    head d16z6
    red valve cover for d16z6!!!!!!
    head gasket d16z6
    intake gasket d16z6
    timing belt d16z6
    Intake manifold d16z6 already on the car!!! DXI (d15b7) with d16z6 intake
    ECU d16z6
    I don't have the distributor from the d16z6 block.
    My qeustion is if i can use my D15b7 distributor with the ecu from B16z6??!!:unsure:
    I know the holes from the distributer don't the match up.
    Thanks calvin
  2. CRX-YEM
    Wallingford, CT
    I think it's possible, you'll need to do some machine work on the bolt hole of the dist. to get it to line up
    Jeff when he's around might have a better answer for this.
  3. Jeef
    Jeef NO MA'AM Moderator VIP
    What is a b16z6?
    What year Civic is the b7 from? I have lost interest in Hondas lately so my memory is slipping.
    If you are using the z6 ecu then you need to use a z6 distributor. I just rewired my car for the z6 distributor.
  4. pissedoffsol
  5. calvin
    NETHERLANDS
    I want to know if the distributer will work(from 92-95 DX)
    with a p28 ecu (sohc vtec 92-95).
    =>Holes don't match, but the plugs are the same!
    So can i use the old distributer?
    Brain what do you think
  6. pissedoffsol
    no idea...
    and i'm Brian, not Brain :)
  7. calvin
    NETHERLANDS
    what did you rewire?
    Jeff?
  8. pissedoffsol
    he did nearly a complete obd conversion on his 91 dx
  9. connervg
    connervg New Member
    i have a 94 coupe ex, that originally came with a D16Z6, but i cracked the block
    so i put in a d15b2 block and the Z6 head is on it now
    the shit is pretty fuckin quick too
    idk if that helps u much tho.
