d16 witha 500cfm holley carburator
plysndrt
does anyone know of this being done before and how it would run if you did.:huh:
That sounds like its way too big. I've never seen anyone use a single carburetor and there are many guys using individual-type ones.
first you need a custom intake manifold, and since the honda engine is small displacement, you would probably be much beter off with a smaller carb, you could still use a four barrel but not 500 CFM.
it probably would not run well except high RPM either. not very streetable.
I say go for it and be the first to rock a holley on a honda!
even cooler if you stick the induction stack out the hood.
Join D-series.com and ask them.
Theres a few guys running carbed setups.
got it done runs just a little bit rich but other than that it runs like a bat out of hell i thought i would have some problems with the injector wiring not being hooked up but it didnt seem to have a problem. will try to post some pics when i get the chance^_^
