yeah, he could just get proper ecu for the head/IM and wire in the pins for the vtec oil pressure switch, and vtec solenoid. he might have a problem w/the knock sensor code though. i am through trying to figure it out. i did the same thing (y7/y8 mini-me with a y8 ecu), but kept having problems w/ a CEL for a knock sensor. tried wiring in a ks, but still had CEL for it. i decided to just get a p28ecu with a conversion harness. the p28ecu doesnt look for a knock sensor, but everything else is the same. advantage to p28ecu is less likelihood of throwing a CEL with modifications.
