hey i have an 88civic which i put the d16a1 out of 89 integra. did compression test found cyl 1 170psi, cyl 2 55 psi, cyl 3 0psi, cyl 4 60psi. and the motor was pouring oil out exhaust while running. so replaced the rings. new head gasket. now just got it running. its running alot better. havent done compression check but still dumping oil out all cyl through exhaust. i need help? maybe valve seal? could i have but the oil ring in wrong?
Did you check the bores for roundness, they may not look worn but no.2 and 3 cylinder can get out of round if its been thrashed because of the open deck design. So the bores could still look good but the rings wont seal properly if the bores are out of round.
