D16a6 w/ D16z6 VTEC Head into 95 Civic EX Possible
Discussion in 'HYBRID -> EG-EK / DC' started by hmtcrxsir, May 28, 2005.
  1. hmtcrxsir
    hmtcrxsir Member
    Since my D16z6 engine is jack up. and i have an extra complete D16a6 engine. I was wondering if I can use the lower block of the D16a6 and the top block from the D16z6 VTEC head and use the existing OBD1 stuff from the D16z6 and switch it over to the D16a6 block. Oh btw, this is going into my 95 Civic EX. You think it would work? Or do i need to buy another D16z6 engine? Shit, and would it pass smog if i did this?
  2. hmtcrxsir
    hmtcrxsir Member
    i guess no one knows.
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Yes it would work... there isnt a 'top block' there is a block and a head. :lol:
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Whether it will pass smog is determined by where you are located.
  5. phunky.buddha
    Dallas / Fort Worth, TX
    Yup. It won't pass in California, but it'll pass just about everywhere else. Use the Z6 head and all your Z6 OBD1 hardware and you'll be fine.
  6. hmtcrxsir
    hmtcrxsir Member
    but wont pass smog? So why bother?
  7. xj0hnx
    C.C.TX.
    In California head swaps are illegal, but we don't know if he is in cali, in not, than he is fine.
  8. CRIXICAN
    CRIXICAN Junior Member
    the head will bolt on and asid from a new head and intake gskts (use the z6 stuff and pop out the risticter in the oil feed line), adn correct timeing belt theres very you need to make it work. I'll have to get back to you on the T-belt.
  9. crxguy88
    crxguy88 New Member
    will that be stronger than the stock z6?
  10. gabe_nogara
    gabe_nogara New Member
    Santa Teresa
    timing belt
    the timing belt ur going to use
    has to match the water pump
    that's it
  11. SWAPPED_94CIVICVX
    SWAPPED_94CIVICVX New Member
    YAKIMA AND ABERDEEN
    mini me swap
    i thought that combo of an EF d16a6 SI bottom end with a y8/z6 head combo is called a MINI ME SWAP.correct me
    if it was me i would just spend the money on the z6 if its almost all there
  12. phunky.buddha
    Yes, but "mini-me" loosely refers to pretty much any D block with a VTEC head swapped onto it. An A6 bottom with a Y8 or Z6 head is pretty much still the same as the original Y8 or Z6- it just has slightly higher compression. The displacement, bore, stroke, block height etc are all still the same.
  13. SWAPPED_94CIVICVX
    YAKIMA AND ABERDEEN
    mini me
    is the mini me better then the stock z6..because you say the mini me has higher compression..i have a z6..
  14. MaxxBoost
    MaxxBoost New Member
    Watch the compression with this set up, and GET IT TUNED. This set up is prone to detonation.
    Components to consider getting:
    Thicker Head Gasket (Lowers compression, preferably a copper one)
    Z6 head (Easier hook up)
    Run Premium (Especially if you' plan on being an ass and NOT TUNING it..)
    Low Compression Pistons (Stock ones will work fine, these would make it extremely streetable though, and would check the high-compression/Detonation problem.)
    Air/Fuel Controller (Adjustable)
    Tune It (I can find you the company you can send the ECU out to, they'll give work it down something sick, V-TEC, Adjustable Air-to-Fuel, V-TEC controller, the whole 9, on multiple platforms even if you swap to a DOHC.
    It sounds like alot, but it's really cheap, and ensures the car's gonna be reliable and won't tear itself to shit, you'd prolly make as much if not more torque then a stock B-16, if it's tuned right, that's minus power gains from Breather, Intake, upgraded pipage from header to rear n' the relative...
    Takin a guess...120 horses, 102 on torque..just a guess. Sleeper.
  15. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
  16. philyphreak2127
    Littleton, co
    wait hold up using the a6 block should lower the compression compared to the z6 motor. shouldn't it?
  17. N/A b18c1
    N/A b18c1 Mysterious
    Mid-Coast
    z6 should be 11:1 something like that
    a6 should be 9:1 as getting a z6 gasket(thinner) should push it to 10:1 just guessing this shit out of the back of my had correct me if im wrong
  18. philyphreak2127
    Littleton, co
    see that is what I was thinking although I think the z6 is more like 9.6:1 and the a6 is 9.1:1(unless we're talking JDM) so it shouldn't change that much, but the d16a6 has the lowest compression of the d-series motors so I figured it can't possibly raise the compression of a z6 motor considering doing a head swap is much like installing low compression pistons.
  19. philyphreak2127
    Littleton, co
    I looked it up but not on this site. :)
