Hey guys, what the heck am I doing wrong here?
I'm doing a d16a6 / y8 mini-me and i've got everything completed except for the Y8 timing belt WILL NOT GO ON.
All of the write ups I've been looking at say to use a z6 or y8 timing belt and it will be tight, but those are all for d15. I'm assuming the a6 must be a little different?
Try as I might, I can't get the y8 belt to go on the tensioner. It's just a hair too tight, and the belt does not stretch at all. I suppose I might be able to use a pry bar but that doesn't seem wise.
I'm still using the a6 tensioner and water pump. Do I need to switch to the y8 ones? Are the pulleys slightly smaller?
Any help is appreciated. Anyone with the same swap please let me know how you got the timing belt on.
