D16B MPFI throttle wheel?
caminator
I have just swapped out my Dpfi for a MPFI and when I try to hook up the throttle cable to the trottle body only one cable slot exists.
I have an auto and for some reason there is a cable going from the throttle to the transaxle.
my problem
I need to be able to hook up both cables in an opposite pull. I tried to swap the old wheel to the new throttle but it wont fit, I was going to modify it to make it work but the springs are wound in reverse.
Does anyone have any suggestions?
Yeah some aftermarket manufacturers have a wheel design for the throttle pully. It's funny cuz I just noticed this on my friend's auto 92 accord w/ F22a1. I dont even know what that's for, if anyone knows, tack it on.
I'd suggest go to your local junk yard and see if you can take the pully off one of the throttle bodies that match yours. You dont need the entire throttle body. This is probably your cheapest, non ghetto rigged solution...
