D16y7 y8 build
Discussion in 'Engine Building' started by Delsol1738, Mar 28, 2017.
  1. Delsol1738
    Delsol1738 New Member
    I have a 95 dealsol si with p28 obd1 ecu and harness for a z6 with a y7 bottom end and y8 head with z6 intake and throttle body an a d15b7 distributer with z6 internals my question is why am I not getting spark all grounds are hooked up an everything should work any suggestions??
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Hey man Welcome to HONDASWAP ! Generally id say to start off with a build thread of your car with pictures of it and the engine and things done to it etc. but ok you are having a problem and slow down there cowboy sounds like a big collaboration of stuff going on there did you just have a bunch of misc stuff laying around and go fack it ? lol anyways your problem long as assembled correctly probably isnt the engine , could be anything from a bad dist to a still a bad ground or in wiring or a fuse even the car would have to be looked at in all honesty , and btw with the collaboration of stuff you put together if read correctly its pretty much still a z6, the block and head castings are the same
  3. Delsol1738
    Car ran fine befor this swap and no I didn't just say fack it lol it was planned not vary well but thanks will look into it more
  4. dilbeckskate
    Kennesaw Ga
    by fack it I ment you threw a random block. bottom end. head. and intake together lol not knocking it
  5. dilbeckskate
    Kennesaw Ga
    It could be something simple as a a bad coil, you need a z6 dist though soo the bolts line up
  6. Delsol1738
    Z6 dizzy doesn't bolt up patterns are different
