d16y8 crower stage 2 turbo head
Discussion in 'Engine Building' started by zackzerr, Feb 17, 2014.
  1. zackzerr
    zackzerr Member
    st louis
    hey guys so i just picked up this y8 head. its been ported and polished. came with a crower stage2 turbo cam and springs and titanium retainers. it currently has stock valves so im ordering crower valves. im planing on about 14 psi to 18 psi. should i get oversized valves or stick with stock size?
  2. Briansol
    stock is probably fine. if you go larger, you probably will have to do more machine work to match (ie, 3-angle)
  3. zackzerr
    zackzerr Member
    st louis
    cost wise its the same for the valves. would it be worth the machine cost to go ahead and over size them? im already dropping 300 for the valves.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    I would talk to someone who knows about the port job that the head has had- you could screw it up by resizing the valve seats for the larger valves. Larger usually is better for flow, but not always. Research before you jump.
  5. zackzerr
    zackzerr Member
    st louis
    would i be best off to buy a cometic 2mm head gasket? or a mls
