d16y8 swap into 92 ex sedan w/d16z6.
Discussion in 'HYBRID -> EG-EK / DC' started by gene, Jan 17, 2005.
  1. gene
    gene Junior Member
    my d16z6 is starting to go and want a cheap swap...
    will the 96-2001 d16y8 longblock swap over onto the eg's using 92 parts
    ie. distributor/intake manifold/throttle body etc?
    any help would be great. thanks.
  2. unsivil_audio
    unsivil_audio Ninja's pwn samuri's.
    Sheridan, Wyoming
    Yes.
  3. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    everything will fit in your civic the only thing is you are going to have plug on the motor that are not in your civic like the crank sensor on by the crank pulley and the heater o2 sensor i think it is the secondary one i hope that helps
  4. gene
    gene Junior Member
    thanks guys
