d16y8 with p28 ecu
Discussion in 'HYBRID -> EG-EK / DC' started by hmooooob, Mar 6, 2009.
  1. hmooooob
    hmooooob New Member
    I have a 96 civic hatch, with a complete change over of a d16y8(using the d16y8 engine harness ( is using the d16y8 engine harness the right move?)
    recently converted to obd1, using a obd2-obd1 conversion harness with a stock p28 ecu
    the question is, do i need to do anything else to suit obd1
    such as changing the Injectors, Distributor, and the Alternator.
    and for some reason my cel is on with code 41 (primary sensor) but its a brand new sensor, any clues to why its still throwing code 41?
    sorry for being a noob, but i really need my car to start working again
    any help would be greatly appreciated
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if you have a 96 car and a d16y8 why did you convert to obd1 why not just stay obd2
  3. JDMB20Coupe
    JDMB20Coupe Powerd With 1 Cam
    Chester, VA
    obd1 is easier to tune. you will need to change the injector clips unless you use the y8 injectors. you will also need to change the alternator and dizzy
