D16z6 compression
Discussion in 'HYBRID -> ED-EF / DA' started by 8ballsin, Mar 23, 2009.
  1. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    i checked my compression on my stock z6 and the normal bolt on mods but my compression was 12, 12, 12, and 13 through each cylinder
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yeah thats really bad
  3. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    any ideas why it would be like that
  4. AHHVTEC
    Alabama
    well lots of things, i would check the timing first. but that being off or bad valves,rings,hole in the pistons,cracked head,bad head gasket, ect
  5. BrokenRex
    BrokenRex New Member
    are you sure you performed the test right? anything below like 100 and the motor probably wouldn't run.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Given the location; I'm assuming the unit of measure is bar. If so, that's about right and you're just fine.
    12bar=~174psi
    13bar=~189psi
    Sounds right; about a 9% difference which is well within spec of what's suggested(which is about 15-20psi difference, or about 1bar)..
    How accurate is the tool you're using though? As I'd honestly doubt you could be on 12 or 13 spot on.
    1 person likes this.
  7. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    its from our local craft shop on post here in german so thanks
