S StealthMode Kung Foolin' Sep 14, 2003 #1 do i need to use a distributor from the EX i pulled the head out of, or can i use mine from the CX? i also need the ECU too?
H Havok Senior Member Sep 14, 2003 #2 The distrubtor is fine, you will nee a.) the EX ECU (P28 or P2P) depending on whcih odb you have, and/or a vtec controller
