d16z6 head, d15b block ecu question
ali_baba
I have a d16z6 head on a d15b block, I just wanted to know which ECU would work with this setup. Does the ecu have to be chipped or could I just use the one for a d16z6 which is p28? If not does anyone know how to chip the ecu for this setup?
What I currently have is this:
Motor
Alternator
OBD1 Distributor
Intake Manifold
SI Tranny
VTEC Solenoid
Missing:
ECU
Harness to OBD1
Am I missing anything else to make this swap happen, and does anyone know how much HP that should give me?
Does it have to be chipped or constructed differently, b/csome guy on a local board was saying something like that but i'm not sure
hey...its same with me....i used d16z6 head with d15 block....i use d15b ecu...before i change with d16z6 head, vtec engage at 4800 rpm....now since i use d16z6 head i cannot feel vtec engaged at 4800...so, shud i change original ecu with p28?.....
Thanks a lot for the info I guess the guy was just trying to rip me off, anyone know where I can get a obd0 to obd1 harness?
