D16z6 Into Ef Clutch Question
Discussion in 'HYBRID -> EG-EK / DC' started by on2wheels, Jan 25, 2003.
  1. on2wheels
    on2wheels Junior Member
    I am planning a D16Z6 swap into an '89 DX Hatchback using the '89 transmission. I've read that I can swap to a '92 up (larger) clutch if I get a '92 up flywheel. If I do this, which release bearing do I use? The '89 or a '92 up? Or will either work?
    Thanks in advance
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    Get a clutch kit or a 90-91 Civic and use the 92+ flywheel. I am 99% sure ti will work. I think that I used my 93-95 flywheel when I put my crx si tranny on.
