D16z6/p28 Wiring 94cx Hatch
Discussion in 'ECU's, Electronics, and Tuning' started by Spyderturbo, Feb 1, 2003.
  1. Spyderturbo
    Spyderturbo Senior Member
    PA
    Hey guys, I have a 94 CX and I am putting a 93 d16z6 motor and tranny run by a 94 P28 ecu in it. I need to know what additional wires I must run, and where I can get diagrams on the ECU plug to connect. The motor came with the engine harness, will it plug right in, then I need to run 3 extra wires from the Vtec solenoid to the ECU and tap in at the pins in my CX connector? God I hope it's that easy :D
    Thanks, Matt
  2. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    Dude, as far as i've heard, you just plug it right in. The vtec wires might already be in your stock harness from the ecu to the bay. check it out and let me know.
  3. Spyderturbo
    PA
    I thought the VX and SI were the only hatches to have the vtec wires run. I know some 92 and 93 models had the vtec already ran but I'm pretty sure that by 94 model year the CX was not pre-wired for vtec.....that would be sweet if it was though :D
    Someone else out there have any idea?
    Thanks, Matt
  4. hybrid4
    Nashville,TN
    Even if, all you need to do is run 3 little wires and your set.
  5. Spyderturbo
    PA
    So it is just the 3 wires? I thought it was only three but I wanted to make sure. If I need to run them I need to figure out where they get run to on the harness :D
    Thanks, Matt
  6. Havok
    Havok Senior Member
    Florida
    These 2 wires run strait from the vtec solenoid on the head to the ECU, A4 and D6
    The green plug is the oil pressure, the gray harness with the yellow/green wires is the vtec solenoid
    CX are not prewired, you need to get a Z6 harness, or extend it and solder.
  7. Spyderturbo
    PA
    Can I just cut the harness wire, extend it, then pin out the CX ECU harness, or are the plugs different. I got the P28 plugs and about 6 inches of wire when I got my ecu today....
    -Matt
  8. SixtySecondAssassin
    Austin, TX
    i used the harness that came with my engine as a guide to see which wires went in which slots in the plugs. you need to run all the vtec wires, and a 4 wire o2 sensor. go here for pinouts:
    http://tech.hybridgarage.com/tech/index.html
  9. Spyderturbo
    PA
    Hey guys, I have a little confusion left on this subject. Okay, I am getting the D16Z6 engine harness with my motor, sorry I left that out before. Someone told me that they had done a swap on a CX and since they got the engine harness they didn't need to run any wires. I was under the impression that the harness that runs from the engine bay to the ECU was not wired for vtec and that I would still need to run wires. I'm totally confused now, but if all I need to do is plug my D16Z6 harness into the Firewall harness plug I will be thrilled. Sorry to re-hash what some may view as already answered, I just wanted to be certain on this....
    I get the motor Friday! I can't wait to be rid of my 72hp CX motor!
    -Matt
